- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Files not opening/ saving as DWG
Due to my files not saving as a DWG I am not able to open my CAD files using the software.
I have uninstalled the programme and reinstalled twice, this problem is still reoccurring.
please help ![]()
windows cannot find 'c:\program Files\Autodesk\AutoCAD 2023\acad.exe'. Make sure you typed the name correctly, then try again.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Did you Check FILEDIA <1>
Try it and replay
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
perhaps try downloading the latest version which is 2024
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Welcome to the AutoCAD forum.
Contact your IT Department to help you fix it with this article:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@molliemae_grant-west wrote:
Due to my files not saving as a DWG ...
That is odd: is this perhaps just a problem of you not having file extensions on in Windows File Manager and you assume whatever wrong label got assigned to DWG files means they are somehow all gone?
You'll need to show us what you mean, what you see and where you see it, with lots of screenshots.
Or just do this https://fileinfo.com/help/windows_10_show_file_extensions
OR... open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
EDU Support Access is here, look for the new automated pop-up with common questions
https://www.autodesk.com/education/support?startHelpBranch=AVA-edu-flow&mode=open&_ga=2.35539169.196...
and here https://forums.autodesk.com/t5/installation-licensing/education-license-renewal-lacks-renew-option-o...
