AVCPlugins
en respuesta a: samuelb8Y56V
Select the desired faces in any way (by clicking or using a frame while pressing CTRL or using the subobject selection mode) and then assign a material and color to all selected solid faces at once. it doesn’t matter whether it’s on one solid or 100 at once.
If you want to create materials with the desired name directly in the properties panel, then the regular properties panel cannot do this, but the AVC Properties Palette plugin can.
(BTW It can create new layers by simply entering a new name in the Layer property of any object)
https://youtu.be/ETIMTQ_Xdbo
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
