Valentin-WSP
en respuesta a: Simon_Mathews
@Simon_Mathews ,
@Simon_Mathews wrote:
do i now right click on palette , customise palette , then right click on each tab name and export that ''tab name.xtp'' file to my local folder where i created them ..do that to all the tabs , then copy that folder with all the .xtp , actpcatalog file and images folder that it created to a place on our network so that others can link to that location ?
or do i have to move everything to the network first and then create the .xtp files ?
do i need to include the .dwgs with all the items from each tab into the folder that goes on the network or just the items listed above ?
  1. Create a specific location on the Network for the Autodesk > Toolpalettes.
  2. Yes, export your "Palettes" (*.xtp) and "Palette Groups" (*.xpg) to this network location.
  3. Yes, you can also copy the AcTpCatalog.atc, DWGS, and other files to this network too.
Note:
  • If the server name is ever changed, you will need to updated the <Source File> (Network Path) within each (*xtp) file.
  • Make sure to add this network file path in the OPTIONS.
  • Also consider creating a PROFILE folder where you can EXPORT these settings (*.arg) and others can IMPORT.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
