Jaeppers
1608 Vistas, 21 Respuestas
Line not highlighting when selected
Usually when I select an existing line on CAD its fully blue and today I highlight it and it only shows the two end and middle points of the line.
In the photo one line is joined and other is a new line. Usually all lines are fully blue and now when I draw a new one its not.
Patchy
en respuesta a: Jaeppers
Let's see your .dwg
Jaeppers
See attached.
Jaeppers
I hit the wrong reply button but the file is the message board
Patchy
It shows ok for me, try your graphic acceleration.
Enter the 3DCONFIG command and click the Hardware Configuration button. Enter the OPTIONS command or choose it from the Application menu to open the Options dialog box. On the System tab, click the Graphics Performance button. Then click the Hardware Acceleration button to turn it off or on.
Jaeppers
en respuesta a: Patchy
So I turned it off and now if i select the line its still not highlighted and now its dashed.
Patchy
and your HIGHLIGHT is set to 1?
Jaeppers
Yes it is
Jaeppers
Before the line problem it was working fine and then I accidently clicked into 3-D mode and then the line problem started after I clicked out of it
Patchy
is it SELECTIONPREVIEW you're using?
Jaeppers
Selection preview is set at 3.
Jaeppers
Also when I select any text that I have it highlights red. Not sure if that can be fixed or not.
Patchy
Probably has to do with graphic card driver needs update.
Someone here will have a link to it.
Jaeppers
I figured out the color thing but the lines are still having the same problem
Patchy
Let's try:
UCS, World then Plan.
Jaeppers
How do I do that?
pendean
@Jaeppers
Your "line" is a PLINE, like the other: do you just need to EXPLODE it?
What is your ABOUT command pop-up list as your exact AutoCAD year and variant?
Your WindowsOS version is...?
Can you also show us the GRAPHICSCONFIG command pop-up too please?
Jaeppers
en respuesta a: pendean
The about command comes up as CAD 2022 with Land/FX.
Windows is the most updated version I think
Patchy
I missed the reply about to 3d then back to 2d.
The command:
UCS
W (for World)
then
Plan
Jaeppers
All it did was zoom me out of model space
