pendean
en respuesta a: irene_dondiego
@irene_dondiego wrote:
Hi, thanks for answering, as you can see in the screenshot i drew the same line and the same circumference two times in AutoCad, then put a thickness of 0.50mm on the second ones. I can't see the line anymore, just its extremes, but still I can see the circunference with the right thickness.
Have you installed the 2023.1.3 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, any difference?
