irene_dondiego
508 Vistas, 7 Respuestas
Problem with the line display
Hi, I have a problem drawing on my AutoCad, of which I can’t understand the source. When I draw using the command line and I choose a thickness other than the default one, I can’t see on my screen the entire line, but just its extremes. Also, when I select a line, I noticed that just its extremes and the middle point get selected. I have this problem both in the model space and in the layout space. I have the problem just with the command line and polyline and I don't with the command for creating a circle or an arc, which I can see with every thickness i choose.
Valentin-WSP
en respuesta a: irene_dondiego
@irene_dondiego ,
Try the suggestion from this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
pendean
Show us what you see: screenshots or video please.
irene_dondiego
en respuesta a: pendean
Hi, thanks for answering, as you can see in the screenshot i drew the same line and the same circumference two times in AutoCad, then put a thickness of 0.50mm on the second ones. I can't see the line anymore, just its extremes, but still I can see the circunference with the right thickness.
irene_dondiego
en respuesta a: Valentin-WSP
Hi, thank you for answering, I tried to follow the instructions, but i didn't solve the problem.
Valentin-WSP
@irene_dondiego ,
Emilio Valentin
pendean
Have you installed the 2023.1.3 Update yet? ABOUT command will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
If that did not help... Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT: reverting to DirectX11 fixes similar problems for most users.
Also consider turning off LINESMOOTHING and LINEFADING variables.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, any difference?
irene_dondiego
I solved my problem installing the new uptade. Thank you very much! I was really worried, you've saved me.
