Zesty46
1067 Vistas, 7 Respuestas
AutoCAD Script to open a .dxf file and save it as a .dwg
I am new to Autodesk scripts, and could use some help.  I've received a few hundred dxf files from a vendor that i need to convert to dwgs.  If someone could assist with writing a script to open a dxf file and save as a dwg, that would be very helpful.  I am running the scripts using proscript if that helps at all.  Thank you in advance!
