- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Is there a way to change the offset distance of the text frame option for Mtext?
Dennis
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you do a multileader without a leader, you can adjust the text frame padding in the Properties palette under the "Text" main heading and "Landing gap" subheading".
Work: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Text background mask you can but I don't think text frame created from TCIRCLE command can be changed.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you copy the MTEXT you want to use into a MULTILEADER (with the leader turned off), you will have the controls you're looking for. AutoCAD has seemingly omitted the functionality to control the padding between the text and border for MTEXT.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@Kent1Cooper
My understanding was this thread was about adding a visible frame (box) around MTEXT, not a background mask.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@nrz13 wrote:
.... My understanding was this thread was about adding a visible frame (box) around MTEXT, not a background mask.
The mask is the way to control the size ["border offset factor"] of the frame. Set a mask to get the size, and turn on the frame farther down in Properties, and if you don't want the masking aspect, you can turn that off, as here [un-checked box], but the frame will keep the size set by the mask.
If you want to change the offset factor, you'll need to turn the masking back on, if only temporarily.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
THAT'S IT!!! I knew there was an unintuitive solution (because Autodesk) that I had used before, but totally spaced on it. I appreciate your help.
Dennis
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Also, if Autodesk is listening, it would be nice to be able to set this spacing with a System Variable.
D
