ArchiFusion
888 Vistas, 4 Respuestas
Rotated model space view?
AutoCAD keeps rotating my model space view, and I'm not sure how to change it back
My crosshairs are rotated
The viewcube is rotate (seemingly the same angle as the crosshairs)
But the NSEW compass is still oriented 90 degrees, with North pointed up. And the drawing is drawn in the same direction.
How to I get the crosshairs cursor and viewcube back to the same orientation? SNAPANG already says its at 180. If I switch the SNAPANG to 13, it goes back to normal, but the Viewcube is still wrong.
pendean
en respuesta a: ArchiFusion
Does this happen in ALL of your files, or just this one?
What is PLAN command set to?
Are you using Dynamic UCS by chance?
Do you need to turn off UCSFOLLOW too?
Did you restart your computer yet?
ArchiFusion
After some digging, I figured it out.  The USC command followed by selecting "World" seems to fix it.
Its been rotating everytime I edit something in paper space and then go back to the model.  Not sure why its happening, but at least there's a solution.
jon.newberry
en respuesta a: pendean
Why is rebooting your computer the end all and be all solution? Rebooting doesn't fix the problem within AutoCAD.
cadffm
en respuesta a: jon.newberry
"Why is rebooting your computer the end all and be all solution?"
Nobody said this!?
"Rebooting doesn't fix the problem within AutoCAD"
It was a question and the answer can help to find the issue and a solution.
In this case here, it was a question or test to know if the issue is temporary or not.
It sounds you have a similar issue?
And it is not ucsfollow?
If you need help: Share your sample .dwg, explain step by step to reproduce it and if possible - a screencast to show the issue.
Sebastian
