08-25-2023
02:52 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-25-2023
02:52 AM
Honestly, I do not know. My AVC plugins have a separate automatic update system built in because these same plugins work not only in Autodesk products.
In addition, it should be borne in mind that the Autodesk App Store has pre-moderation of all updates, which takes from one month to six months or more. So the store does not have the latest versions of plugins.
BWT: You can try editing the PackageContents.xml file yourself. If you just fix the AutoCAD version then most .Net plugins will run fine on new versions of AutoCAD because the AutoCAD .Net API hasn't changed in a long time. But it won't work with ARX plugins.
