paullimapa
en respuesta a: agalvanm
if you're using a high definition screen on Windows 10 try this setting on the shortcut that you use to launch AutoCAD:
  • Adjust display settings Windows 10
    Right-click the application, select Properties, select the Compatibility tab, and then select the Disable display scaling on high DPI settings check box.
  • Or
  • Change application properties In Explorer or on the Start menu, right-click the application name, select Properties, select the Compatibility tab, and then select the Disable display scaling on high DPI settings check box.
    Note: In Windows 10 Version 1703 and later version of Windows, the text of the Disable display scaling on high DPI settings option is changed to Override high DPI scaling behavior, scaling performed by: Application.
Paul Li
IT Specialist
@The Office
