pendean
en respuesta a: catherine_heincke
Greetings @catherine_heincke
A few dumb questions if I may:
1) Are you unfamiliar with Annotative Text and dimensions and objects by chance? That seems to be what has happened.
2) Or you are familiar with it, but the settings are way off? For example you recently changes from using units=mm to units=inches in that DWG file? Or did you manually change STYLE settings to make a text larger not realizing it have a bigger impact like this?
3) or is this a file from someone else that you two need to discuss about together since that is how they set everything up?
