08-23-2023
04:35 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
08-23-2023
04:35 AM
Were the assemblies drawn by others? AutoCAD is a 3D program and those elevation values may be important.
Better solution if you don't want you additions to use elevations would be to set the OSNAPZ (System Variable) to 1 and make sure the ELEVATION (System Variable) is set to 0. Any objects or dimensions you add using osnaps will be with an ELEVATION of 0 without converting the entire drawing to 2D which might make it useless to others.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
2023
