ChicagoLooper
en respuesta a: mikegera
Hi @mikegera
Try this:
  1. Select the objects you are measuring.
  2. Right-click=>click Isolate=>Isolate selected objects
  3. Change the View Cube to from TOP to FRONT.
  4. Zoom-in. Are the objects on the same plane? Is one higher than the other?
  5. Right-click=>Isolate=>End isolation
If the objects are at different elevations, your dimension won’t be accurate.
Chicagolooper
