- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
See the screencast below. What on earth could be causing this?
Edit: added 2nd screencast below.
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @mikegera
Try this:
- Select the objects you are measuring.
- Right-click=>click Isolate=>Isolate selected objects
- Change the View Cube to from TOP to FRONT.
- Zoom-in. Are the objects on the same plane? Is one higher than the other?
- Right-click=>Isolate=>End isolation
If the objects are at different elevations, your dimension won’t be accurate.
Chicagolooper
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hey @ChicagoLooper ,
The circle and the line are both on the same plane. But, I did notice that some entities in the assembly I'm working with are not, and that could be affecting things.
What is the best way to push everything in the drawing to Z=0?
Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Were the assemblies drawn by others? AutoCAD is a 3D program and those elevation values may be important.
Better solution if you don't want you additions to use elevations would be to set the OSNAPZ (System Variable) to 1 and make sure the ELEVATION (System Variable) is set to 0. Any objects or dimensions you add using osnaps will be with an ELEVATION of 0 without converting the entire drawing to 2D which might make it useless to others.
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Tom,
Thanks for the very helpful rely. Often drawings are a mix of blocks from many sources. Sometimes, I don't realize that there's 3D content.
Is there a way to globally "turn off 3D"? i.e. outright "disable Z"?
Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For some reason, the FLATTEN command does not always work. For example, I found a text entity that had a nonzero "Position Z" (21.3655). FLATTEN did not change its Position Z to zero, it remained at 21.3655.
I also found that FLATTEN cannot penetrate blocks. Is there a setting to allow it to do so?
Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @mikegera
Do you know whether this drawing began in Revit?
Yes, it did or no it didn't? I don't know and I don't care?
Is it possible to upload more screenshots?
Select a text entity nonzero "Position Z" then upload a screenshot with the text is still selected. Include the Properties Palette in the shot so the text can be evaluated.
Next, select a block which cannot be penetrated and upload a screenshot with the block is still selected. Include the Properties Palette in the shot so the block can be evaluated.
BTW, do you run Revit? Is this an architectural drawing?
Chicagolooper
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Chicago,
1. Sorry for the delayed response.
2. I do not use Revit. While I am not the originator of the drawing in question, I'm nearly certain that Revit was not used at any point.
3. This is not an architectural drawing. It's an electrical schematic.
4. I did make an interesting discovery: the issue is NOT present in AutoCAD mechanical. It IS present in AutoCAD electrical.
I am not ignoring your other questions, but thought I'd share this first.
Thanks.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
If you can figure out the FLATTEN issue to get it to always work, you could set AutoCAD to run a LISP each time a drawing is opened (in your acaddoc.lsp file) that flattens it first. It would do it for every drawing you open, even one that's already been flattened, but it would keep you from accidentally working in a 3D drawing.
Work: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
