Pointdump
en respuesta a: jfukunaga981
Hi Jeremy,
It's not possible to get any elevation values from your DXF, except by manually changing the Z of each contour in Properties. If you started with a shapefile in QGIS, then the workflow suggested by @Patchy is the easiest way.
Even if you had elevated contours, Vanilla AutoCAD will limit what you can do with them. Civil 3D is best for working with surfaces.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
