ChicagoLooper
en respuesta a: paullimapa
Is your site LA County, California? Or in Canada?
Flattened drawings are typically done to put all objects at Z=0, or all entities at mean sea level.  By placing all objects on the same drawing plane, distances can be accurately determined from plan view.
If your drawings only need to measure horizontal distances the flattened command will allow a user to ignore Z-values and only consider the X- and Y-components of distances.
Foe example, if you have two adjacent points in a drawing, the dimensioned distance between them might be 24.6.meters. On the printed hardcopies, though, they only ‘appear’ to be 3.5 meters apart. Why? Because one point is at the top of a waterfall and the other at the bottom. Or on top of a building for one point and on the sidewalk for the other.
Flattening a drawing using the flatten command doesn’t mean to put objects on a single layer, it means to out all objects on the Z=O plane or to ‘remove’ all elevation from the drawing, to make it flat. The layers can remain at status quo.
If you draw using Civil3D, this might, or might not, require extra steps in addition to using the flatten command, especially if you create TINs b/c surface elevation is critical to your scope of work, such as final surface grade and water drainage.
Does your office produce engineering type plans and do you frequently require agency approval for those plans?
Chicagolooper
