Kent1Cooper
en respuesta a: jstein
Diagonal Stacking gets you closer at the same fraction height ratio:
[the dashed green aligns with the base of the 1 in the middle Dimension].  I don't know of a way to get the "baseline" position consistent other than to use vertically-centered text:
[which I find easier to read correctly anyway when there are multiple parallel-dimension-line strings of them as in your images, but circumstances force them to be much closer together].
Kent Cooper, AIA
