Kent1Cooper
en respuesta a: jstein
I don't see any in your image that are not centered as defined in the Dimension Style.  You have it centered only in the Horizontal direction -- if you mean you want this kind of centering:
that's the Vertical Text placement position [the slot above the one that is set to Centered], which you have set to Above.
Kent Cooper, AIA
