paullimapa
en respuesta a: 899358501
if you have not been saving your dwg since you opened it to work on then you may be out of luck....
you should also check your savetime setting which AutoCAD uses to do automatic saves to temp files.
but still no guarantee that those autosaves won't be corrupted either.
that's where the "save early, save often" phrase comes into play
Paul Li
IT Specialist
@The Office
