cedrick_paquet
403 Vistas, 4 Respuestas
Autocad File not opening.
I have been working for months on this file, wich won't open.
When I click on the file, It opens, but is frozen and I can't do anything. Opening a new drawing works, and other files work.
Please help me.
pendean
en respuesta a: cedrick_paquet
Things to try (see link below) if you are not able to just share that problem DWG file here
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corru...
rkmcswain
Insert the "bad" DWG into a new empty (no template) DWG.
Explode it.
How's that?
Valentin-WSP
@cedrick_paquet ,
@cedrick_paquet wrote:
... It opens, but is frozen and I can't do anything.
This this:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
paullimapa
perhaps you can share the problem dwg here?
or if the dwg has xrefs, move the dwg to another location where the xrefs cannot be located and see if the dwg opens then.
Paul Li
IT Specialist
@The Office
