gcarvac
385 Vistas, 4 Respuestas
VIEW CULLING BREAKING TRIM
I am using the trim tool to remove a line. Because my item is quite large, I need to zoom in to select the correct line to trim. Unfortunately, this means the intersecting lines are outside my view. The trim tool then removes the entire line instead of up to the intersecting lines. Is there a way to improve this?After trimAfter trimBefore trimBefore trim
