Kent1Cooper
en respuesta a: BB8x
Further questions:
In Situation 1, what do you picture as the procedure?  You call a command, and the User does...?  Select a 3DPolyline first, and then pick on a vertex grip and be asked how much to change its elevation?  Pick at a vertex directly, without picking the Polyline first?  More than one vertex adjustment within one running of the command?  If so, a separate request for distance for every vertex, or all that you select adjusted by the same distance?  Etc., etc.
In Situation 2, by "text's elevation" do you mean the Z coordinate of the object's insertion point [that's really easy], or is it about numerical text, and you want to change the number represented by the text's content?  [Or both?]
Kent Cooper, AIA
