- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
@sgeraciC5Z7G wrote:
which is my local "My Documents" Folder.
Correction, OneDrive
With your screenshots I can totally follow along now and in AutoCAD 2023 (not sure you are) does exactly what you now clearly shows, PDF ends up in a different folder (I set MY DOCUMENTS as the "default location" but not the OneDrive subfolder).
BUT if I then run it a second time soon afterwards, it does show up in MY DOCUMENTS.
if I chose a third location, the second location is used the first Pub2PDF time. the third location is used the second Pub2PDF time.
Very odd. How far did your testing go?
If everyone else here can also replicate it like you and I can, you know what you need to do in the interim until that's fixed. Did you do create/share the above screenshots and step-by-step progress with the Autodesk team by chance? You might want to add to their information.
Best wishes.
