Mahiratse
398 Vistas, 3 Respuestas
Can i add many views to a sheet, including 3D view?
I want to know if it is possible to put many views in one layout page including 3 pdf assembly drawing. If needed, I can send you an example. Thanks for help
[ The subject line of this post has been edited for clarity by @handjonathan Original: Re: Meet the new Autodesk Assistant in 2024.1 and more]
pendean
en respuesta a: Mahiratse
Yes you can. Try it now.
Mahiratse
Did-you send me an answer on my question? I remind that I need to put many views on one layout page, including 3 d dwg format. After printing, I want all views to be in pdf in one page (including 3d pdf). The example I said on my first message is a pdf file from a colleague which I want to learn how to make this kind of mixed pdf. Thank-you
Valentin-WSP
@Mahiratse ,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
