7Archaeologist84BFCP
441 Vistas, 4 Respuestas
Line that is fixed distance from another line (not an equidistant!)
Good day,
I have encountered a situation where I need to draw a boundary of a protected area fixed distance from an object (60m). Problem is that there are corners in the complex polyline, which means that in order to draw a line fixed distance away from vertices I'm going to need to draw arcs, as illustrated in green on a square below (not an equidistant in red! Corners are further away than required). Is there an AutoCAD feature for this or maybe a LISP? I can't imagine that manually drawing arcs for the 1000+ vertices is an optimal solution. Due to language I don't even know how to name this problem in order to search for it properly.
Any help with this is greatly appreciated!
