jdfnnl
503 Vistas, 3 Respuestas
PDF frame snapping
Why does snapping to the pdf frame seem to become disabled as I scale this pdf larger? The smaller instance snaps to all four corners, but the larger only to the insertion point. Is this observable on other machines? Mine is running ACAD 2015.
paullimapa
en respuesta a: jdfnnl
Is your pdfframe set to 1 or 2 so you can see it and snap to it?
https://help.autodesk.com/view/ACD/2023/ENU/?guid=GUID-9FC48ACE-3962-4977-B2BB-CD90984E91D6
Paul Li
IT Specialist
@The Office
Kent1Cooper
I don't have any idea of a cause or suggestion to fix it, but just to confirm:  Yes, the same happens for me, in Acad2024.  And if I change the larger one's Scale to various arbitrary other values [larger and smaller], without changing anything else, I can Osnap to its corners.  When I try at the original Scale using ENDpoint Osnap, it does actually "find" a location, but it's at 1'-5",0'-11" no matter where on the boundary I float the Osnap target.
Kent Cooper, AIA
paullimapa
like @Kent1Cooper I tested this on AutoCAD 2024 but also in 2020. They both behave the same. I even tried the RECOVER & AUDIT command.  When the drawing first opens the pdf with the larger scale of 62.0347 cannot be object snapped to. But once I modify the scale even slightly like 62.03471 now I can object snap to all corners.  So I wonder if it's the way it was placed using your AutoCAD 2015?
Paul Li
IT Specialist
@The Office
