dseaton
272 Vistas, 2 Respuestas
Splines not scaling correctly in differently scaled viewports
hi there,
I have come across what appears to be a bug in AutoCAD where splines are not showing at the correct scale in differently scaled viewports. However if i use 2D POLYLINE, POLYEDIT THEN SPLINED WITH ATTRIBUTES FIT / SMOOTH=CURVE FIT & LINETYPE GENERATION ENABLED then it shows correctly. see attached drawing and screen dump,
Etiquetas (1)
