dseaton
270 Vistas, 2 Respuestas
Splines not scaling correctly in differently scaled viewports
hi there,
I have come across what appears to be a bug in AutoCAD where splines are not showing at the correct scale in differently scaled viewports. However if i use 2D POLYLINE, POLYEDIT THEN SPLINED WITH ATTRIBUTES FIT / SMOOTH=CURVE FIT & LINETYPE GENERATION ENABLED then it shows correctly. see attached drawing and screen dump,
Etiquetas (1)
Valentin-WSP
en respuesta a: dseaton
@dseaton ,
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
imadHabash
Click on below image and see how it looks fine .. i open you dwg directly after downloaded . pick inside your viewport and REA ( Regenall command ) .
Imad Habash
