07-19-2023
06:57 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-19-2023
06:57 AM
@sam_underdown wrote:
.... the level is displayed as +100.00
I have removed the + sign and the command works, the + sign was causing me the problem!
There must be something else going on. When I make Mtext just like that, UUMT works to remove the underlining. Do this at the Command line:
(cdr (assoc 1 (entget (car (entsel)))))
and select an Mtext object that UUMT doesn't work on [i.e. that is not recognized in UUMT's selection]. What does it return? The one I made returns this:
"{\\L+100.0}"
and I suspect yours will have some other complication making it not fit the selection filter criteria. [Like maybe, does the underlining actually start after the + sign?]
Kent Cooper, AIA
