Kent1Cooper
en respuesta a: edezzie
@edezzie wrote:
On one of them is a block, and I cannot edit it in place. It gives an error.
Well, the error is:
Command: REFEDIT
Select reference:
Errors found in references to other objects:
** Application reference missing: ACAD, to AcDbLinetypeTableRecord.
So apparently its definition uses a Linetype not available to your AutoCAD.  If that's also a Sketchup import, maybe that's the reason.
But I can edit is using BEDIT rather than REFEDIT.
Kent Cooper, AIA
