- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Neither the image nor the drawing file makes it clear what/where you are trying to Hatch. But yes, a lot of the possible objects involved are at varying Z coordinates.
If you can correct that with Properties or the FLATTEN command, you should be able to Hatch. If there's some reason you can't do that, one thing you can do is to draw a Polyline using the PLINE command, Osnapping to endpoints, etc. That will result in something all at the same Z elevation, and you can Hatch with Object-selection of that. But if it's Associative, it would be to that Polyline, not the the things the Polyline was drawn over, so if you want the Hatch to adjust to changes, you should keep that Polyline and change it along with the other elements that it overlays.
