07-17-2023
12:15 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-17-2023
12:15 AM
Looks like your drawing is infested with objects in this case LINES that are not 100% on 0 elevation.
For JOIN 2 Lines:
I used Express Tools FLATTEN command on both LINES and then the LINES joined successfully.
For Edit Block in Place:
There's been various threads describing similar problem:
https://forums.augi.com/showthread.php?176597-REFEDIT-sending-error-on-saving
https://zaldy4.rssing.com/chan-32337793/article7.html
There's no real good solution other than to use BEDIT command instead of REFEDIT & then ERASE the LINE & recreate a new LINE, then save the block. Now you can use REFEDIT on it.
