tyomalv
315 Vistas, 1 Respuesta
"data extraction" function does not work (AutoCAD 2024)
Hello, the "data extraction" function does not work on the latest versions of AutoCAD 2024. If you select certain blocks in the current drawing during extraction, the "next" button does not work. If you specify the current drawing for extraction, the objects are extracted from another drawing, although it is not in the list. In the versions of AutoCAD 2021 and earlier, everything works great!
