rayKVD8F
229 Vistas, 1 Respuesta
Problem extruding spline
I am trying to extrude this spline to create an uneven ground surface but i keep running into the problem of hollow solid. The spline is connected as i used close command once drawn and when i do smaller splines it extrudes fine.
Is there a way to make this work? Is it not working because of the uneven heights?
