06-30-2023
08:29 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-30-2023
08:29 AM
I have attached the original file I made which does work on these. I just need to select multiple. I think swapping in SSGET does not work because then it tries to run on the entire selection set instead of each entry. I do not know how to get it to reference each entry as it passes through but I believe I have the loop part correct. The one labeled "Modified" is not currently working and has the loop, the other one works but only on one selection at a time.
