Kent1Cooper
en respuesta a: bemmer7MZ3G
Mine called PolygonToCircle.lsp doesn't work in your sample drawing because it requires regular polygons such as the POLYGON command makes [all edges the same length, all vertices the same distance from the center], but:
The one called PLS2C.lsp does it by drawing a 3-point Circle through the starting vertex and two others approximately 1/3 and 2/3 of the way around, so how the resulting Circle relates to the original Polyline can very a lot depending on how close to circular the original is.
Kent Cooper, AIA
