vinodkl
en respuesta a: bemmer7MZ3G
Hello @bemmer7MZ3G
From the drawing, I could notice that the closed polyline are not equidistant so they won't be called polygons. You would need a different lisp to work on your requirement.
Apologies, my knowledge of lisp is not very much:cara_sonriente_con_la_boca_abierta_y_sudor_frío: so here is what I found on the forum(See attached) which would work on your requirement. Credits to @Kent1Cooper :cara_con_una_leve_sonrisa:
Type in the command PLS2C to execute the lisp.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
