Kent1Cooper
en respuesta a: acadadmin3KNUF
For the channel stringers, LOFT worked for me, using the Path option and one of your Splines for the path:
I would suggest a Helix path instead, though.
You should be able to build the end shapes for the "bed" part, between the stringer ends at top and bottom, and do the same.
EDIT:  I tried it -- see the attached.  The Helix paths are in magenta color, along the lower corners of the stringer parts.  Aside from my leaving in place the end pieces that I Lofted between, I think I got the equivalent along a spiraling path of your flat one.  It's located with the center of the spiral at the origin because moving your Spline-based spiral arrangement there was how I figured out what the radii should be.
Kent Cooper, AIA
