- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Please see the attached file. I have a 90-degree-turn, flat-level conveyor bed modeled in flat surfaces. I also need this modeled as a spiral-up bed. The file has the line geometry needed, but I can't successfully make opaque, solid-surfaces. Is what I want even possible?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For the channel stringers, LOFT worked for me, using the Path option and one of your Splines for the path:
I would suggest a Helix path instead, though.
You should be able to build the end shapes for the "bed" part, between the stringer ends at top and bottom, and do the same.
EDIT: I tried it -- see the attached. The Helix paths are in magenta color, along the lower corners of the stringer parts. Aside from my leaving in place the end pieces that I Lofted between, I think I got the equivalent along a spiraling path of your flat one. It's located with the center of the spiral at the origin because moving your Spline-based spiral arrangement there was how I figured out what the radii should be.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
OK I confess...I totally "cheated." I suddenly realized I could simply export my INV files to ACAD, explode the blocks and get the surfaces that way
