pendean
en respuesta a: draftingPPLZJ
Greetings @draftingPPLZJ
The HP drivers for your HPDJ510 are installed in Windows just like HP wants you to do, you don't "put them" anywhere else for AutoCAD (and your other programs) to use.
If you are trying to create PC3 files from that already installed Windows driver (they are not drivers BTW, those are pointers with presets), those go in the folder that opens with you run PLOTTERMANAGER command in your AutoCAD 2022.
HTH
