ducvanvt
216 Vistas, 1 Respuesta
SOLPROF command with/without inner solid edge
I'm having some issues with using solprof command with the cylindrical solids created from mesh, so the solid is not actually a tube solid.
The problem is when I use Solprof on bigger tube the inner edges of the solid disappear, while with smaller tube they persist. I have attached the cad file here for example.
I would like to get rid of the inner edges within the boundary of the solid, just like what happened with the bigger tube. Do you know why this does not happen with the smaller tube ? and how to replicate this effect on the smaller tubes?
