06-22-2023
01:45 PM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-22-2023
01:45 PM
@The_Angry_Elf it's 2023, nothing is too big to share when it cannot be attached ![]()
It would appear their video card is not up to the task: is the problem limited to this one DWG file?
Is this a laptop (or a desktop) and is it set to use the default "iris" graphics instead of a better added video card for AutoCAD?
And/or...
Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD. That is likely to help
Also consider turning off LINESMOOTHING and LINEFADING variables all the time.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If all else fails, then turn off Hardware Acceleration as a last resort, see if that is the cure.
