pendean
en respuesta a: MaccyDee
Greetings @MaccyDee
Set GFXDX12 variable to 0 (that's a zero) then restart AutoCAD/LT: see if that helps.
Also consider turning off LINESMOOTHING and LINEFADING variables all the time.
If still no relief then start GRAPHICSCONFIG command and change the 2D Display Settings pulldown from "advanced mode" to one of the other choices.
If still no relief, set COMMANDPREVIEW command  to 0 (that's a zero).
If all else fails, then turn off Hardware Acceleration as a last resort, and start a support ticket with Autodesk through your subscription portal as explained here https://knowledge.autodesk.com/customer-service/account-management/users-software/support-options#:~....
