pera3dcad
1064 Vistas, 6 Respuestas
command TXTEXP (Explodes text into polylines)
Hello everyone
I use the explode text command TXTEXP (Explodes text into polylines).
I would like to be able to adjust the line lengths.
In the example I posted, the line lengths are automatically defined to a length of 1.26 mm.
Can I choose the length of the lines, for example 0.2 mm or 0.05 mm???
I would like the contour to be smooth.
Please look at the picture!
Does anyone know how?
Valentin-WSP
en respuesta a: pera3dcad
@pera3dcad ,
Read the suggestion by Autodesk:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
pera3dcad
en respuesta a: Valentin-WSP
Thanks for the reply and I appreciate your advice.
I already use this.
I want the ability to adjust the length of the lines.
thank you
Valentin-WSP
@pera3dcad ,
@pera3dcad wrote:
... I want the ability to adjust the length of the lines.
Sorry, this option is not available.
Maybe "Edit vertex" with PEDIT may help or just "Add vertex".
Emilio Valentin
pera3dcad
Thanks for the reply, I was hoping it was possible.
Have a nice day
jamieq
I tried exploding some text at various zoom levels, and with the text at different sizes, and it seems the length between polyline vertices is dependent on the size of the text. With 10" high text the smallest I could get the length is about 0.079" or 2mm. But with 5" high text I can get the length to 0.035" or 0.9mm. But of course, the length scales with text size. So if you were trying to get smaller lengths between vertices and exploded 25mm high text, then scaling it back up to 50mm will result in scaling the lengths up 2x.
But what you could when the text is exploded is run PEDIT on each polyline and change them to splines. The vertices remain the same, but it smooths out the polyline into a nice curve. I'm not sure exactly what you're trying to accomplish after the text is exploded. But if you do change to splines, just keep an eye out because sometimes weird glitches happen and pline ends get connected when they shouldn't, etc.
pera3dcad
en respuesta a: jamieq
Thank you for your reply.
I tried that, we have similar experiences with SPLINE.
A few years ago I learned a great method that was shown on the Mechanical Advantage YOUTUBE channel.
The results are excellent. I use this method.
But when I have a lot of letters it takes a lot of time.
I hope there is some way to achieve great results (smooth transitions) with less time.
Mechanical Advantage channel link https: //youtu.be/Ux1UUxgXduU
have a nice day.
