- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
I am unable to select the 'midpoint' of the Dimensions with the current settings in AutoCAD 2024, this has never occurred before. All other items/ objects have ability of 'midpoints' being selected. Any solutions or ideas please?
¡Resuelto! Ir a solución.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Greetings @desjacobs
Midpoint of dimensions? Show us what you mean, even if you have to fudge it please.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
You can Osnap to lots of MIDpoints in Dimensions:
If you mean the point midway between the Dimension's definition points, use M2P/MTP Osnap between the NODe Osnaps on the definition points. Type in the M2P or MTP, or Ctrl+right-click or Shift+right-click and pick it:
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
It would appear that none of the OSNAP Settings are working for the Dimensions. All other items are working as required, any ideas? Thanks in advance.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
are you really sure you are using a product named AutoCAD 2024?
Please share your ABOUT dialog.
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Start command ABOUT
Make a screenshot: https://support.microsoft.com/en-us/windows/use-snipping-tool-to-capture-screenshots-00246869-1843-6...
Paste or attach [Browse] your screenshot.
>>"AutoCAD 2024"
Okay. Is it a problem in every drawing, also in this drawing (attached) ?
Sebastian
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Try these suggestions:
If using AutoCAD 2024 Mechanical:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
What exactly? Good to know for other Threads in the future.
The links are
1. about another Software
2. Disabled osnaps, so it won't work with any objecttype, not only dimensions.
Sebastian
