cadffm
en respuesta a: Vuxvix
>>"This is my Default :Text, Above dim line. Is it different from yours?"
No, as you can see it use same command as I mentioned.
>>"But it doesn't change anything."
You described it (or it sounds for me} as working for one object but not for multiple.
But that's not true and I was right with my guess, you're trying to edit a dimension that you can't edit with it,
it doesn't work for one dimension object either, OR? why should it work for 2 or 100?
Mark such a dimension and look in the properties, the values for text position are gray.
( This is due to the individual properties of the object )
_
I also wonder why two Lisp files are now appearing without a word
and I'm even more amazed that you have a function in it that solves exactly this problem {DTA2}.
Now I don't even know what you want and why. laugh.
Sebastian
