Vuxvix
en respuesta a: TheCADnoob
This is my Default :Text, Above dim line.
Is it different from yours?
P/s:I did it the same way you did(Autocad 2021). But it doesn't change anything.
I noticed, when I enter the command, autocad won't execute the command. I can only execute the command (Above Dim line) from the right click pop-up. while "Text home" can be done in any way (command input, pop-up, shortcut).
