cadffm
en respuesta a: Vuxvix
>>"I want to apply " Text Above Dim Line*"
Where or why are you reading/writing "Text Above Dim Line*"
>>"but "*" is not."
What is that * ????????????
>>"And "Above dim line" is not."
It works the same way as the other one (BUT I can not see the macro/command you are using),
if it is the original one, it should work - the command is AI_DIM_TEXTABOVE
Sebastian
