amandabF6NY3
en respuesta a: pendean
@pendean wrote:
Perhaps you forgot to QSAVE that DWG file before publishing again? Or you edited the incorrect DWG file or Layout?
I definitely save often, but I can't be sure I've qsaved before every publish. I will try to make sure I do this. However, this has me thinking about whether or not the problem is related to the part of our title block that is saved as an xref DWG. Most of the time when I see this problem occur, I've recently made changes to that xref. It's not likely that I would confuse the two because one is literally just a table, but I will try consolidating those two drawings and see if that solves the issue.
@pendean wrote:
does anyone else in your office have these issues with your files and SSM too?
I will try and see if they can reproduce the issue, however the problem has persisted since before I was moved onto a new workstation.
Thank you for your help, I will make some changes and update when I see the issue again.
